ok.... how do i hook this up to run..
Old Jan 24, 2009 | 11:20 PM
X_Demonite_X's Avatar
Car: 06 impala 87 iroc z-28
Engine: 350 5.7 TPI
Axle/Gears: Pontiac WS6
hello every one im the dumb guy who bought a half hooked up camaro with a crap interior thats me yep dumb dumb .... soooooo how or where do i start hooking this motor up to start im a ameture in the engine but im pretty good with electrical and body work right now the engine starts but does not stay running i noticed some coolant on the intake valve cleaned that up and havent done much since the kid i got the camaro from just put a new radiator hose on and that might not be sealed or torqed i know some things but im at a los right now can and will email closer pictures upon request i know for sure the vacum hose's are not all connected and there is a hose on the passenger side valve cover that doesnt go anywhere
please help
Attached Thumbnails ok.... how do i hook this up to run..-img_1750.jpg   ok.... how do i hook this up to run..-img_1752.jpg   ok.... how do i hook this up to run..-img_1753.jpg
Old Jan 24, 2009 | 11:29 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: ok.... how do i hook this up to run..
Go take a picture overlooking the entire engine bay, standing from the nose of the car.
Edit. PS- I like the spark plug in the A.I.R. hose.
Old Jan 24, 2009 | 11:37 PM
r62mcmahon's Avatar
Car: 1989 IROC
Axle/Gears: BORG WARNER /3:70
the hose on passenger side valve cover connects to stock air cleanr. you can just use a breather in place of hose.
Old Jan 25, 2009 | 01:07 AM
chevy89camaro's Avatar
please help
cap your delayed vacuum (left) on front of carb and plug your distributors vacuum advance into the one on (right) also on front of carb.
Old Jan 25, 2009 | 01:25 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
very classic and orginal
Old Jan 25, 2009 | 01:40 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Edit. PS- I like the spark plug in the A.I.R. hose.[/quote]
you have a really good eye lol. had to do a double take on that one.. then i laughed for about 5 mins..
Old Jan 25, 2009 | 11:43 AM
Engine: 350 5.7 TPI
that spark plug is throwing me for a loop... hehe
Old Jan 25, 2009 | 11:47 AM
Engine: 350 5.7 TPI
hopefully these will help will have some overhead pics later
its only 2 below zero outside today my poor garage heater can beraly keep up
Attached Thumbnails ok.... how do i hook this up to run..-img_1838.jpg   ok.... how do i hook this up to run..-img_1839.jpg
Old Jan 25, 2009 | 11:57 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what was the engine in the car origionally? was it FI or carb? is there a mechanical fuel pump on the block? passengerside front down low. Is the carb flooding causing it to die?
Old Jan 25, 2009 | 12:13 PM
Engine: 350 5.7 TPI
im not sure what was in it originaly probably a factory 305
not really sure whats in it now add on car said 350 owner of car said 305 father in law says 454 .... trust his judgment but he is not happy that i got another camaro ... wife has a 86 that her mother tboned still getting parts for that.......
here is a pic of the pass front low looks like a new part i figured it was a waterpump but then again i dont know much about motors.... have been studying up though i took the battery out when i first got it cleaned all the oxide off the connections put it back in and it did start up pretty good but i have to feather the gass pedle. started it up about a week ago when it was warmer out to see if it would run on its own and it didnt and since then have had a stron gass oder in my garage so that might be it didnt see any gass leaking but its hard to tell ice is still melting off the car
wont let me upload any more pics....... will email on request or email me thanatos66@hotmail.com
Last edited by X_Demonite_X; Jan 25, 2009 at 12:17 PM. Reason: Automerged Doublepost
Old Jan 25, 2009 | 01:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
father in law says 454 .... trust his judgment but he is not happy that i got another camaro ... ----------
454 , stop listening to him he apparently knows nothing
Old Jan 25, 2009 | 01:17 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
OP, I too am love'n the spark plug in the hose. I've only seen that particular mod performed once before, and that was my Country Uncle Jamie. He's the originator of "duct tape can fix anything" As for the advice earlier about hooking the distributor to the proper side and place, thats about all I can tell you to help you ATM. However I will offer you a bit of advice, from my personal experience those "el cheapo" chrome valve covers will cause you more headache than they're worth. Once you get your engine running properly, do yourself a favor get a quality set of valve covers.
Old Jan 25, 2009 | 01:22 PM
Engine: 350 5.7 TPI
been searching through catalogs year one looks like the best one so far but some items are more expensive then even ecklers newvalve covers is on my list wasnt sure if i should go with cast iron or cromed out edelbrock..... seams to be the theme so far but what preforms better out there..
Old Jan 25, 2009 | 05:56 PM
Mrgref92's Avatar
Car: 1986 Camaro Sport Coupe
Engine: L69
Transmission: 700-R4
Axle/Gears: 2.73's
Check if the fuel lines are kinked in any places
Old Jan 25, 2009 | 10:09 PM
Doc_G's Avatar
Car: 87 Trans Am
Maker doesn't matter as much as quality of product, do you know if your block is pre-86/post-86? There are entire dressup kits out that cost less than 200.00 thats valve covers, open air filter cover and base, and timing chain cover I believe. I personally like the black ones, and depending on which route I end up taking for my engine/tranny combo would get them in a heartbeat. They also have a natural finish, as well as what I've heard refered to as "industrial silver"
They are in My jegs book, I'll see if I can get you some part numbers if your interested.
Z28/ZR1
Oct 23, 2015 01:04 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
