Why won't my firebird start?
Old Jan 25, 2009 | 01:24 PM
kodysformula's Avatar
Car: 1989 Formula Firebird
Engine: 5.7 TPI
I have an 89 formula firebird 5.7 tpi. Why won't the engine start after it gets hot? I have to let it sit there for a while to start it again. My dad said its after it gets hot. And it has fuel pressure.
Old Jan 25, 2009 | 01:53 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: Why want my firebird start?
How much PSI is the pump pushing?
Old Jan 25, 2009 | 02:18 PM
Engine: 5.7 TPI
Im not sure the Psi is the problem because we have already hooked a guage up to once and it was fine. But it normally on does it when I go pump gas. The gas station is like one of two blocks away so i didnt it would get that hot.
Old Jan 25, 2009 | 02:34 PM
Engine: 5.0 TBI
I don't know what you are trying to say . If you " hooked up a gauge once", then hook it back up and get the PSI rating at idle and WOT.
Old Jan 25, 2009 | 05:58 PM
jblong1's Avatar
Re: Why won't my firebird start?
yur starter cranking
theshackle
Mar 5, 2017 06:37 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
zeitghaist
Aug 18, 2015 07:33 AM
