How to buy heads
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
How to buy heads
Probably going to look at a set of 083 heads tomorrow that were pulled from a blown motor. Guy said they're from a crate motor. He said there's beads of melted aluminum visible on the backside of the valve from the engine blowing. Does this make sense? I wouldn't pay much for them, but should I even bother? How can I know if they are salvageable just by looking at them? Can I set em on a flat granite table to see if they are warped?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: How to buy heads
Yea, you can set them on granite to see if they are flat. But it sounds like it needs all new valves, probably a valve job, and most likely to be decked.
Keep in mind 083 heads are not particularly magic or special at all.
I wouldn't pay more than $50 for them, if they needed work. Otherwise i'd just be looking at aftermarket heads or something.
Transmission: 4L80E/4L80E
A granite table doesn't work very well because you can only see the outside edges. A straightedge is better for the task.
At the very least the heads should be disassembled, cleaned, and checked out thoroughly. A money-back should be assumed if they don't check out. Who pays the shop fee for checking them will have to be negotiated.
I don't know of any crate engines that came with 083 heads. A replacement engine 10-15 years ago, maybe.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
I went ahead and sprung for em. Ended up paying $50. I suppose if they turn out to be bad I'm not out too much.
083's are the best for my application with the exception of $1400+ aftermarket heads. They will bolt on to my LO5 in place of the 193 swirl ports, run fine under my TBI, can be reasonably modified to accept a 490 lift cam, flow to 5500 in a purely street driven car, and allow retention of all factory-looking LO3 smog equipment/EGR for CA emissions, who still think I have an LO3 under the hood.
Mickeyruder
Sep 2, 2015 02:45 PM
