valve? in vacuum line to cc
Old Feb 2, 2009 | 06:15 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
What is the purpose of the small line that comes out of this valve, and where does it go, after it goes through the firewall? It's in the vacuum line to the cruise control.
Also, what is the large aluminum object, cylinder shaped, maybe 5" long x 1.5" in diameter, under the wiper motor?
Old Feb 2, 2009 | 10:35 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: valve? in vacuum line to cc
I believe it's a check valve for your HVAC system. It keeps it from switching to defrost when the vacuum goes low.
Old Feb 3, 2009 | 01:05 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Thanks for the answer!
That seems logical... one check valve probably used for both CC and HVAC, since there is a vacuum resevoir on the same side of the valve as the hoses that go to CC and under my dash.
Now, about my second question...
Old Feb 3, 2009 | 04:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
The wiper motor.
Old Feb 3, 2009 | 09:54 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Oh... I thought that what was above it was the wiper motor. Shows how much I know.
Thanks!
Also, what is the larger vacuum line (approx. .5" OD) that goes from the CC, through the firewall, on the drivers side, for?
Does it go to the brake pedal?
Bubbajones_ya
Aug 28, 2015 02:17 AM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
