how long to replace flywheel
Car: 1987 IROC-Z Camaro
Engine: 350ci
Axle/Gears: stock 3.27
someone told me my flywheel was broken and that is why im haveing a starting problem. how long should it take a garage to do that job because i was told thats not something i could figure out in my driveway
Transmission: 4L80E/4L80E
It can be done in a driveway. Almost impossible for us to say if you could figure it out in your driveway without knowing more about the type of work you have done on the car.
I don't know what the book says, but I'd guess a shop would probably spend a day on it. 8 hours of labor times their labor rate (often above $75/hour these days), plus parts (flywheel, clutch disk & pressure plate, throw-out bearing, pilot bearing) & lube.
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: how long to replace flywheel
Engine: 5.7L/350
BlackphantomZ28
Aug 31, 2015 10:29 AM
