upper intake leak/ bars stop leak ok?
Old Feb 9, 2009 | 03:25 PM
theMAGICALheat's Avatar
Car: 96 Souped up Firebird, 89 KITT
so, I now have this small leak in the upper intake. Of course that means a gasket replacement but I am not going to spend 600 bucks when I can virtually buy a used 350 from the local auto salvage for less than that.
Anyone used the bars stop leak (radiator, pelletized the red/yellow bottle) yes, i have the 89 pont. firebird with a 350 engine (swap)
Old Feb 9, 2009 | 03:35 PM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
Re: upper intake leak/ bars stop leak ok?
I would like to ask a question, What does water and oil pass through? Answer galleys in the engine and radiator. Any type of stop leak will plug any small holes/galleys if you want it to or not. The company that came up with stop leak, bars leak or what ever they want to call it should be shot. I would not put any chemical to plug holes in any type of engine....
Old Feb 9, 2009 | 06:02 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
I have used it before and it works temporarily. However, it will start leaking again sooner or later.
Make sure you don't over do it. Don't put too much of the stop leak. After you replace the gaskets, make sure that you flush your cooling system.
Also, make sure that you don't have an internal leak. Intake gaskets are not that much of a pain in the behind to replace. Just make sure you don't cut any corners and that you take your time.
Old Feb 9, 2009 | 08:36 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
Don't use it... it is snake oil and will not work well or at all and causes other damge.
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 8, 2015 12:07 PM
