062 vortec heads question
Old Feb 9, 2009 | 07:48 PM
Sovuf's Avatar
Car: 86 IROC
Engine: Soon 355
Hey guys, this is a good question for one of you tech genius
So I bought a block already bored .030 over for 30 dollars.... you heard me 30 dollars While rebuilding, I heard about 062 Vortec heads, and I may be able to get them. I am definately going with them if I can snag some. I need a cam that the heads can handle.
My question is.. How big of a lift can these heads handle with stock springs and rockers? I am aiming for at Least .460
Thanks to anyone who answers my question.
Old Feb 9, 2009 | 08:10 PM
Abubaca's Avatar
Re: 062 vortec heads question
Max lift according the CHP, which may or not be right, is .420 to .430
....but you can mod the valvetrain/springs to handle whatever you need. I wouldn't stop at such low lift after all the work to build the motor.
Old Feb 9, 2009 | 08:13 PM
Sovuf's Avatar
Car: 86 IROC
Engine: Soon 355
Ah well, I beleive it may be closer to .460 but I am unsure. The reason I want to go with stock springs is a money issue. I can always upgrade to a bigger cam and springs in the future. I have all the tools needed.
Old Feb 10, 2009 | 12:00 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The springs are not the limiting factor on Vortec heads. It's the bottom of the retainer hitting the top of the valve guide boss/valve seal. The set I had a few years ago would take about .450" ish. They require machine work for more lift.
Old Feb 10, 2009 | 09:45 PM
Abubaca's Avatar
YES SIR!!!! You're right. ....I was thinking stock L98 heads, which is something I dealt with a few years back. Sorry for the mis-info
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
