Help guys
Old Feb 10, 2009 | 11:02 AM
1991CamaroRS4me's Avatar
Car: 91 rs and 88 z28
Transmission: th350
Axle/Gears: 373
Help guys
I need some help guys, I have a 88 Z28 with a built 350.
Edelbrok performer intake and carb(650)
64 DBL hump heads 202/160
Comp cam 501/501 292 ADV Dur
HEI with adj. advance
TH350 w/3000 stall
10 bolt rear end w/ 373 gear
.22 domed pistons running 11.85 to 1
My problem,
Was not running hardened push rods and bent a couple. Ireplaced them with Mollies. Now i cant seem to get enuff vaccume to run the vaccume advance and my vacume gage is going wacky. I put a vaccume pump on the advance and it is holding and i was able to time the car that way but as soon as i hook it up to carb it stops working. Did i kill my cam or is it something else?
Old Feb 10, 2009 | 11:12 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: Help guys
Crazy vacuum gauge can be a valve problem. I'd do a compression test looking for a bent valve. If that passed, I'd take off the valve covers and watch each rocker as the engine is cranked looking for a wiped cam lobe or rocker lifter issue.
Old Feb 10, 2009 | 11:05 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Help guys
Well a big cam will have low vacuum. It will also have "crazy" vacuum in the sence the needle will vibrate due to the overlap. Because of the low vacuum they also recomend for big cams to attach the vacuum advance to strait manifold vacuum rather than the ported vacuum that you would normally hook up the distributor to. Now there could always be bent push rods ect but big cams will cause issues with the vacuum
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
