fan in shroud quest?
Old Feb 11, 2009 | 07:44 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
how far in is a mechanical fan supposed to be inside the shroud? i have mine flush with the shroud . it dont go in at all. is it supposed to? which is better cooling on the radiator?
Old Feb 11, 2009 | 07:51 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: fan in shroud quest?
As long as it's far enough in so that the fan blades don't draw air from around the engine bay or anywhere else, other than through the radiator, is fine.
Old Feb 12, 2009 | 03:58 PM
Engine: 355
it aint even near the radiator at all. should i move it closer to run cooler?
Old Feb 12, 2009 | 06:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The blades should be centered under the lip of the shroud.
sheachopper
Jul 31, 2019 11:27 AM
Reid Fleming
Oct 10, 2015 09:56 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
