Need help badly!!!
Old Feb 12, 2009 | 02:15 PM
1BadaGTA's Avatar
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
Need help badly!!!
Ok my car has been running just fine the last few months, but I was out the other day sitting at a light and click the car just shut off on me???
So I found that I don't have any spark. So I replaced the cap, rotor, icm, coil, and I still don't have spark!!! I took a test light to the coil plugs (Gray and Black) and turned the key to on. They all showed that they were getting power. But when I checked the coil to distributor cap wire it doesn't show any kind of power??? I'm out of ideas so does anyone else out there have any??
Old Feb 12, 2009 | 07:09 PM
1BadaGTA's Avatar
Re: Need help badly!!!
Anyone??
Old Feb 12, 2009 | 08:14 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
if youre not getting power from the coil to the cap, take one of your other wires and run it from the coil to cap. if the car starts, then you need new wires.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
