Gains from Ported HSR?
Old Feb 12, 2009 | 08:49 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Alright guys, I think I'm getting greedy here. I am thinking about sending my HSR to get ported by Lloyd Elliot so i can see even bigger gains. I'm wanting to hear what people have gained/or not from porting out their HSR. I'm wanting another 30-40cfm out of the intake.
My goals are mid to low 11's NA and slapping 100 shot of NX on there for mid to high 10s. Lloyd already sent me the custom cam and wouldnt you know it, i want more!
Old Feb 12, 2009 | 09:24 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Gains from Ported HSR?
i ported mine but dont have a before/after. I can tell you tho there is alot of material that can be removed, but most importantly there are 4 runners that need reshapened to ease transition of the air column to the head. 4 runners are straight shot into the cylinder head port, the others have a curve to them. If you grind abit on the short side radius you can straighten out that port.
Round off the edges at the top of the runners to ease the air flow into the runners from the plenum.
Port match the manifold side ports to your head port size. There is enough room to really open it up to a true 1205 port size even tho AFR port sizes are slightly different. I know the Eliminators are but the old style i'm not sure which i think is what you have correct?
Main benefits of porting the HSR is to straighten flow to those 4 curved runners but i havent seen before and afters. I have seen from several places that teh HSR out the box flows in the 268-278 range depending on runners/etc. Thats good flow. But since alot of good heads flow in the 270-290 range+ its nice to make sure your intake flows alot more than the head to make the head the limiting factor
Head can only flow as much as the intake manifold lets through
Old Feb 13, 2009 | 01:27 PM
Car: 92 Camaro
Axle/Gears: S60 373
yeah i have the old style AFR's and if i have the money, id yank the heads and port 'em out to 200-205cc. I know that would be a pretty penny too but hey gota pay to play.
I'm pretty sure that I'll hit my goal of mid 11's with Lloyd's cam and the 373 upgrade, but im kinda wanting low 11's NA now hahaha. Our cars will NEVER be finished!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
bplessy
Sep 30, 2015 12:14 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
