what valve springs????
Old Feb 13, 2009 | 06:19 PM
my90bird's Avatar
Car: 1990 firebird formula
Engine: 5.0 tpi
Transmission: t-5
I'm going to be changing my cam and when I do I want to change out my springs but not sure what the size is.they got some at summit for around 70.00 for a set of 16 not sure if them would be good.the cam I want is a comp cams thumper,they got 2 I was looking at,either the:::::
08-601-8
or
08-600-8
Old Feb 13, 2009 | 06:20 PM
my90bird's Avatar
Engine: 5.0 tpi
Transmission: t-5
Re: what valve springs????
08-601-8
or
08-600-8
the stock springs wont work with either of these cams right??well thats what I was told
Old Feb 14, 2009 | 12:05 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What heads are on the car now?
Old Feb 14, 2009 | 06:57 AM
my90bird's Avatar
Engine: 5.0 tpi
Transmission: t-5
there the stock ones
Old Feb 14, 2009 | 07:09 AM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
The springs need to be matched to the cam. buy them as a set. Remember that all important valve job while the heads are off. Use good clamp seals on your valve stems. dont use the cheap umbrella ones.
I have several new cams here in my shop with matched springs. I have new lifters and valve seals for you application.
This is new never used stuff. Let me know if you are interested.
Jeff
Old Feb 14, 2009 | 07:49 AM
my90bird's Avatar
Engine: 5.0 tpi
Transmission: t-5
I'm looking for the choppy idle.the motor is only a 305 but in the future I'm swapping to a 350.email me at my84camaro@metrocast.net and we'll talk more about the sets you have
Old Feb 14, 2009 | 08:31 AM
my90bird's Avatar
Engine: 5.0 tpi
Transmission: t-5
would this spring kit at summitracing.com be good?
SUM-174000
Old Feb 14, 2009 | 10:24 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
If they're stock heads, without any machine work whatsoever, then neither of those cams will work as they have too much lift for the factory configuration. .470-.480" lift is about all a stock head can take (one has to measure to be 100% certain), before the bottom of the retainer hits the top of the guide boss.
Old Feb 14, 2009 | 10:28 AM
my90bird's Avatar
Engine: 5.0 tpi
Transmission: t-5
even if I change the springs?
Old Feb 14, 2009 | 10:37 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Changing the springs doesn't change the fact that the valves are the same length, which dictates at which height the springs sit at.
Old Feb 14, 2009 | 05:59 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Either cam is way too big for a 305 TPI engine without any work to the heads.
Just because you can change springs and retainers to survive the lift doesn't mean you'll be happy with how it runs.
I'm just suggesting to look more into a reasonable cam choice.
Here is the recommendations for the 08-601-8 cam from Comp.
http://compcams.com/Cam_Specs/CamDet...?csid=217&sb=0
Both spring recommendations are for a beehive design which will require different retainers. The 918's will fit the stock spring pockets but you'll need to measure the install height before assuming anything.
You'll also need to check for piston-to-valve clearance and if the pushrods will rub in the slots of the head.
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
