305 roller set up in any 350 engine?and tpi on a 350 vortec?
Old Feb 13, 2009 | 06:47 PM
my90bird's Avatar
Car: 1990 firebird formula
Engine: 5.0 tpi
Transmission: t-5
can I put my 305 roller set up in any 350 or does it have to be a newer one?also,would my 305 tpi system fit on a 350 vortec?
Old Feb 13, 2009 | 06:59 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: 305 roller set up in any 350 engine?and tpi on a 350 vortec?
If it is the factory roller you are refering to you would have to have the 87newer block. Only these blocks have the bosses for the cam retainer plate and lifter "spider" to bolt to.
As for the tpi, you would have to have a tpi base from edelbrock or SDPC because the vortec utilizes taller intake ports and only four vertical intake bolts on each side.
Old Feb 13, 2009 | 07:02 PM
my90bird's Avatar
Engine: 5.0 tpi
Transmission: t-5
okay so any 87 and up 350 I can put my roller cam into?and on the vortec 350's can I change the heads to my 305 or are the blocks different?
Old Feb 13, 2009 | 07:10 PM
my90bird's Avatar
Engine: 5.0 tpi
Transmission: t-5
in other words what year 350's can I get to put my roller cam set up and tpi system in it,I just want to change out the block.my car is a 90 formula 5.0 5 speed
Old Feb 13, 2009 | 07:28 PM
jkris53406's Avatar
Where are you located? I have a reman 350 if you're close
Old Feb 13, 2009 | 07:34 PM
my90bird's Avatar
Engine: 5.0 tpi
Transmission: t-5
southern maine
Old Feb 13, 2009 | 07:45 PM
jkris53406's Avatar
Are you up for a road trip?? JK. Any 350 block newer than 1987 will have the bosses you are looking for . The trruck motors did not have the roller cam but gm cast all 350 blocks after 87 with the provisions for rollers. Good luck!
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
