Fuel filter & Fuel regulator ?'s
Old Feb 14, 2009 | 09:30 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
I a in the middle of plumbing my camaro . My question is can I put my fuel filter (2.5 canister type ) before my fuel pump , and will I need one in the line between the pump and carb .
I also want to know if I can run both lines to my 4150 carb from the regulator . One line in two lines out . I do not want to plug the one side of the regulator .
Old Feb 15, 2009 | 02:35 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Fuel filter & Fuel regulator ?'s
Yep, fuel filter can go before the pump. I personally run a screen filter before the pump and a fine filter between the pump and regulator.
Assuming you've got the typical in the bottom, out the sides deadhead, yea, you can run the sides to either inlet of your carb.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
g.l.mos
Aug 22, 2015 12:02 AM
92camaroJoe
Aug 13, 2015 06:07 AM
