how much lift
Old Feb 16, 2009 | 11:53 AM
runningagain's Avatar
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
how much lift
I bought a 79 truck and would like to know if I used those heads, how much lift can I get out of them without alot of machine work? Would like .500+
Old Feb 16, 2009 | 12:10 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: how much lift
Stock GM heads are good to about .470" lift due to retainer to valve seal clearance. But you should always double check. Aftermarket springs and retainers will raise that limit a little bit.
Old Feb 16, 2009 | 07:00 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: how much lift
Chances are the heads are large chamber smogger POS's that aren't really work investing any form of money into.
Old Feb 16, 2009 | 07:55 PM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
Re: how much lift
Thanks, I'm just trying to get the most out of what I got. I only have the 79 heads and the 193 tbi heads, figured the 79 are better?
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Jorlain
Oct 8, 2015 01:57 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
