Potential MAJOR problem with block?
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I purchased a 383 LT1 a while back and it has been sitting covered in my garage which is heated for a few months now. I finally have money to finish it and I quickly looked through the holes at the rear of the block that get the two large freeze plugs and I thought I saw some rust inside the block
It was dark last night and I didnt have my camera but I am taking pictures the second I go home this evening but how serious can this be?
If its just some surface rust am I ok? Would this just effect the cooling system or am I in for catastrophic failure if I attempt to run the engine and there is some minor rust in there. I need a closer look today but I cant even sit still without know what is going to happen now...
By the way this engine was completely rebuilt with new internals and all block work was done at a local engine/machine shop and at time of purchase everything seemed perfect.
Any help/thoughts would be appreciated
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Potential MAJOR problem with block?
That's about as normal as sand in mexico. Blocks will get surface rust in the water jackets. Totally normal.
Car: 1992 z28
I guess a good flush after initial start up will help clean out any crap in there...
