No compression?
Old Feb 19, 2009 | 09:12 PM
360Iroc's Avatar
No compression?
Rings were installed per box instruction...
Turn the engine over by hang with spark plug in the hole and can hear air coming from the oil pan.
Whats going on?
Old Feb 20, 2009 | 09:37 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: No compression?
Spray a little WD40 in the spark plug holes. This will help get the engine started and able to run. Did you hone the cylinders? If so, follow the break-in instructions. If not, the rings will not seat correctly and you will need to pull it all apart again. And as long as you didn't line up all the gaps, you should be fine.
Old Feb 21, 2009 | 10:23 PM
360Iroc's Avatar
Re: No compression?
All of the rings are 180 from each other. Block was bored .030 over then honed. Its a 12.0-1 engine.
Seems what you have said was repeated by a friend of mine. He suggested the same thing. The engine is not in the car yet. I was just turning it over to adjust all the valvetrian. I could never remember my last one doing this.
Old Feb 21, 2009 | 11:18 PM
ljnowell's Avatar
Re: No compression?
If you are 100% sure that you have the rings in right, you may still have nothing to worry about. If the rings were in upside down, it could cause something like that. However, without the force of combustion gasses forcing the rings into place, you may get quite a bit of that. The pressure being generated just isnt enough to seal the rings to the bore.
Old Feb 22, 2009 | 10:22 AM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
Re: No compression?
Did you check piston clearances? Ring gap?
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
