what is supposed to go here?
Old Feb 20, 2009 | 11:53 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Im taking a look at i may buy today, and i noticed something in the engine pic. Can someone tell me whats suppose to go where i circled in red.
BTW: its an 1988 Iroc, 350ci
Old Feb 20, 2009 | 11:59 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: what is suppose to go here?
IIRC, that's just a valve to release the pressure in the A/C system. Kind of like the valve stems on your tires.
So, to answer your question, I believe it is as it should be.
Old Feb 20, 2009 | 12:15 PM
Rick1805's Avatar
Car: 1992 Camaro
Engine: small block chevy 355/300hp
There is normaly a black cap covering that. A A/C tech would connect his gauges there and there in another smaller one down the line to check and refill your A/C system
Old Feb 20, 2009 | 10:22 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
I believe the above 2 posters are correct, that is a standard schreader valve that you can use to purge or pressure test the system. If you buy an "AC recharge kit" from your local parts store it'll most likely connect to this port.
-Zander
Old Feb 21, 2009 | 12:34 PM
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
Yes, that is the low pressure side where you fill up the A/C system with refridgerant. Ive had to do this a time or two. The other one on the hose is the high side, you do not want to use this to fill up the system as this has high pressure when A/C compressor is running.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
KO1
16
Oct 15, 2015 05:00 PM
Eric-86sc
Sep 28, 2015 11:37 AM
mfp189
Sep 27, 2015 09:25 AM
