Oil Pressure Switch?
Old Feb 21, 2009 | 02:15 PM
Kyle5113's Avatar
Car: 92 Camaro RS
Transmission: automatic
ive been trying to figure out why my oil pressure gauge isn't working in my camaro and i've been searching through the site. i own a 92 camaro rs with a 305 carb. i do not see anything like the bell shaped sender unit anywhere near my distributor, and the only other one i see if about the oil filter, is this the oil pressure switch? if so why does it look different than the part from autozone?
Old Feb 21, 2009 | 05:41 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Oil Pressure Switch?
That's the OP switch for the fuel pump. There is one on the block, behind the intake, on the drivers side, down low, that runs the gauge.
Old Feb 21, 2009 | 05:59 PM
50bmgshooter's Avatar
that's your oil pressure switch. it works your gauge and I here your fuel pump after oil pressure is there.
my gauge on my 91 wasn't working just changed out that sensor and now it works fine.
Old Feb 21, 2009 | 07:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If it's a 3 wire, yes, it is the combined sensor for the gauge and the pressure switch.
Earlier models the switch and sender were seperate units. Later were combined into 1.
Old Feb 22, 2009 | 11:02 AM
Kyle5113's Avatar
Car: 92 Camaro RS
it only has 2 wires coming off it
Old Feb 22, 2009 | 12:31 PM
its still the oil pressure switch you need to change to make your gauge work.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
