TPI Engine Wiring Issue, need wiring guru's input
Old Feb 22, 2009 | 04:40 AM
ParkerTPIz's Avatar
I am in the process of completing a TPI swap in my 1990 rs and i am having an issue with the fuel pump circuit not functioning.
THE FACTS
-The car is a 1990 Camaro rs and came with a 305 TBI auto.
-The engine and wiring all came out of an 87 Trans Am Gta, and it is a 350 MAF TPI auto setup.
-It has all new sensors
-All of my relays are in working condition
-All of the sensors and plugs has been appropriately placed
-The fuel pump has been replaced to an 87 TPI pump (it has been tested and works fine)
-The Car wiring worked perfect with the last engine harness
-The Trans Am motor and Harness had no issues.
-The Trans Am motor blew and i had the motor professionally rebuilt. I then proceeded to swap the setup into the 90 rs because the 305 tbi blew also
THE ISSUE:
-Something is wrong with the fuel pump circuit.
-Everything else has been tested for power and ground and works correctly
-The sensors and plugs have all been checked and rechecked based on appropriate diagrams
-The pump will only turn on if it is powered with a jump wire.
The main issue is the fuel pump does not turn on when the key is turned to the on position. I need for the pump to turn on and function correctly.
Where could my problem possibly be? Could it be because i put an 87 harness in a 90 car? Thus causing a connection problem at the bulk head?
I have ran out of options and ideas and i could really use some help. Thank You all.
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
