'82 Z28 about to make a purchase
Old Feb 22, 2009 | 06:34 PM
jdlgt90's Avatar
Car: '82 Z28, T-Tops, White
Engine: 305 4bbl
Transmission: 4 speed manual
Axle/Gears: stock as a rock
I have been looking around for a z28 with a manual transmission for a while now, and Im pretty sure I've found the one.
It is an '82 Z28 305, carburetor, 4 spd manual, t-tops, white.
66,000 original miles
I drove the car for a little bit, it seems very solid, tested the posi rear end with a nice burn out, everything worked find there. The only red flag was a pretty good size exhaust leak that seemed to be coming from passenger side of the engine, basically just in front of the firewall, I couldn't tell if it was a valve cover leak, or something else.
The engine was very responsive, and the tranny shifted very well, the clutch was done in 1995, and very few miles have been put on it since.
I will be putting the car on a lift before I make my decision, but I wanted to check with this forum first to see what the major problems are with these cars, and what I should take a second look at.
Any help would be greatly appreciated
Thanks,
J.D.
Old Feb 22, 2009 | 07:34 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: '82 Z28 about to make a purchase
Valve cover will leak oil not exhaust.
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
hectre13
Aug 26, 2015 08:17 AM
z28addict8490
Aug 7, 2015 08:48 PM
