Security system......... Needing help!!!
Old Feb 22, 2009 | 11:26 PM
89 RS CAMARO's Avatar
Car: 89 RS CAMARO
Engine: TPI 350 5.7 ltr
Transmission: T5 5spd manual
Axle/Gears: 3.08
Ok so i have an 89 rs camaro with the vats key system and i went to get in my car the other day to move it and when i turned the key thier was nothing like a dead battery but then i realized the security light on my dash was coming on when i would try and start it. i have to seperate keys and neither would work so i think the chip in the key isnt the issue but then again i could be wrong. where should i beging to fix this problem? thanks hope to here from you guys.
Old Feb 27, 2009 | 06:56 PM
ILUVMY89's Avatar
Re: Security system......... Needing help!!!
x2 i have the same problem only i switched out the steering columns and have the vats box for the new on only dont know were the box is so i can switch it out
Old Feb 28, 2009 | 12:50 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is a tech article linked from the thirdgen.org homepage about VATS.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Tonyy_z
Aug 12, 2015 07:20 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
