best stock replacement valve springs to use????
i have a stock l03 tbi with stock cam that iam putting 081 heads on does any one know what springs i would need to replace the old stock ones?
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: best stock springs to use????
Depends on what type of ride and handling characteristics. I removed the stock softer LT springs and threw in some 1LE springs from the dealer a while back.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
err, cylinder head springs, or suspension springs?
Also - why stock? Why not comp 981's?
lol yea valve springs i dont mean like another stock spring but just any brand spring that will be the same size and work with the stock cam
Transmission: 4L80E/4L80E
The LT1/Z28 springs are decent. It's what I'm running with the ZZ4 cam.
The Comp 981's mentioned are good, too. http://store.summitracing.com/partde...5&autoview=sku I'd recommend changing the retainers and eliminating the stock exhaust rotators while you're at it.
sailtexas186548
Aug 26, 2015 03:32 PM
NBrehm
Aug 25, 2015 11:49 PM
