heads and cam combo
Old Feb 26, 2009 | 04:15 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
heads and cam combo
Very similar to the what cam question.I have a GM crate engine with the following #,s block 1024388c heads are#10110810.has cracked head.The block is being cleaned up new bearings newrings etc.what is a good replacement set of heads and a cam for this setup.I currently have $800 for cam and heads if possible.Then I will purchase a carb and intake any suggestions would be helpful.This is my first engine build
Old Feb 26, 2009 | 07:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
$800 isn't going to buy you much. I was going to suggest a Vortec head kit from sdparts.com, but although a good deal, you're looking at about $1000-$1100 for heads, intake, gaskets, bolts, and rockers.
This engine has dished pistons, right? You might want to find a pair of 416, 601, or 081 305 heads. Have them cleaned up, put in a nice Comp or whatever cam in the 260 adv duration range, with new valve springs. You could probably do that for $800.
Old Feb 27, 2009 | 10:53 AM
howy03's Avatar
Re: heads and cam combo
Thanks,that combo is in my range I will check it out.Good price for all that.It has the dished with 4 half moon recessions in it.
Old Feb 27, 2009 | 11:45 AM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
You can find 305 vortec heads for cheap 58cc chambers will bump your compression and they flow well. I put a set of comp 918 springs on mine it ups the max safe lift for your cam to .550 and they reduce oil temp a little. you need to shim the heads to get the correct install height i think mine needed an added .030 to be correct on all springs.
https://www.thirdgen.org/forums/engi...let-305-a.html
your gonna have to get a vortec carb manifold but they can be found used for 50bux or new for 150 on ebay.
I used a tpi cam was in the .520 lift area and 224dur the lift was good but i would get something with a little more durration if i had the chance to do the build again.
It was a nice setup i beat a buddys firebird that had almost the same setup but he had 350 vortec heads and a holly carb same headers intake and close to the same cam.
hope this helps
Old Feb 27, 2009 | 12:03 PM
five7kid's Avatar
Then those aren't the full dished pistons, and 64cc heads will be fine.
84z96L31vortec
Aug 20, 2017 12:16 AM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
