speedo acting up
Old Feb 26, 2009 | 06:22 PM
9teen9dee1 Z-28's Avatar
speedo acting up
i have a 91 z and the speedo goes crazy when its plugged in. i'll only be going like 5mph and the gauge will peg out then go back to zero. also the tranny tries to shift into overdrive . i unplugged it and the tranny shifts ok at best. i have no idea whats goin on with it, anyone know a solutiuon?
thanks
Old Feb 27, 2009 | 08:55 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: speedo acting up
well i havnt worked on a 91 and i know they have a different electronic speedometer so i may be totally wrong here but in previous years the trans would send the speed signal to a "vehical speed sensor buffer". What it does is conditions the signal into a form the speedometer and the ECM can use and the ECM uses that signal to determin things like the torque converter lock up. So you may want to look there and see what if its ok.
Old Feb 27, 2009 | 09:05 PM
rolling thunder, thanks for the quick reply. i have actually found out why the speedo isnt working.......apparently, who ever had the car before me had put a 4L60 vss in instead. WTF! i'm getting the right vss and, hopefully, that fixes it.
Old Feb 27, 2009 | 09:10 PM
Yea it was funnie i was think thats odd the 700r4s shift points arnt controld by the computer? Well that explains it lol
Old Feb 27, 2009 | 09:16 PM
Wait a min the 700r4 is the 4l60. I was thinking u meant 4l60E because that trans does have electronically controlled shifts.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Luigytico09
Oct 1, 2015 08:46 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
ironbmt
Sep 27, 2015 06:00 AM
