How do you take apart an IAC?
Old Feb 26, 2009 | 09:09 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
The IAC's that were used in TPI and I believe also TBI engines. How do you take them apart?
I have already gotten the pintle out but appears you can take apart the IAC itself around where the electrical connector plugs in. Does it screw out? Or is it permanately glued in?
Old Feb 26, 2009 | 09:28 PM
Rick1805's Avatar
Car: 1992 Camaro
Engine: small block chevy 355/300hp
Re: How do you take apart an IAC?
Nope cant take it apart I have used carb cleaner to clean the carbon off of some that I have re-done but thats about it
Old Feb 26, 2009 | 09:53 PM
Car: 1985 Z28
Well, what I did was scrub the pintle clean.
As for the iac I took a can of wd40 and stick the hose down inside the iac, then injected it full of wd40. Let it sit for 10 minutes then repeat to flush. After doing this 3 times I noticed the worm gears on the pintle were no longer covered in black crud after removing it from the iac. Hopefully this does the trick.
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
