Car Blows Smoke
Old Mar 2, 2009 | 08:23 PM
Steve87Iroc350's Avatar
Car: 1987 Camaro Iroc
Engine: L98/350 T.P.I.
Axle/Gears: Borg Warner 9 Bolt with 3.27 gears
Car Blows Smoke
I have a 87 IROC Camaro with a 350ci L98 tpi motor. I changed the stock intake manifold to an eldelbrock intake manifold and put brand new Bosch injectors with bosch spark plugs, msd plug wires, and have checked the timing of the motor. The car tends to blow lots of smoke even when warmed up, I dont know if its how the injectors were installed, or if im running to much fuel pressure and having the car possibly run rich.
Old Mar 2, 2009 | 08:32 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Re: Car Blows Smoke
What color is the smoke? It could be number of things, water or too much gas could be it. Does it smell like too much fuel? Does it run rough or smooth? Also check your vaccum lines.
The more info the better.
Old Mar 2, 2009 | 08:37 PM
Re: Car Blows Smoke
The smoke is white and smells like fuel, It really stinks, but the car starts right up and it runs pretty smooth and sounds like its being drowned out by something.
Thanks for your help.
Old Mar 2, 2009 | 09:03 PM
DJ Delsym's Avatar
Car: 86 Iroc
Re: Car Blows Smoke
White smokes means coolant leaking into cylinders. If it were me, I'd put a vaccum gauge on there and see where it sits cause it will give you a good indication if you have a manifold leak. Than I'd do a compression test on all cylinders, than lastly I'd do a leakdown test.
Old Mar 2, 2009 | 09:15 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Car Blows Smoke
Your intake gasket might be leaking. Make sure there no coolant in the oil or you'll be looking for a new engine soon.
Old Mar 3, 2009 | 02:02 PM
DJ Delsym's Avatar
Car: 86 Iroc
Re: Car Blows Smoke
Why would you need a new engine? After you fix the problem, change the oil, run it for maybe 50-100mi than change again.
Old Mar 3, 2009 | 02:21 PM
jv9999's Avatar
Engine: 5.7L/350
Re: Car Blows Smoke
Antifreeze destroys bearings. I was saying not to run it that way for long or he will need a new motor. Sure, if he catches it quickly, fixes it, and changes the oil a couple times it should be OK.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
fonzie85
Exterior Parts for Sale
Oct 10, 2015 10:55 PM
squiggy2
Aug 9, 2015 09:30 PM
