Heat Soaking? VATS?
Old Mar 5, 2009 | 06:24 PM
kodysformula's Avatar
Car: 1989 Formula Firebird
Engine: 5.7 TPI
Heat Soaking? VATS?
I have a 350 tpi formula firebird. I can crank it up no problems and sometimes it will hit instantly and other times it will take a few seconds. But anyway after it warms up it will not start until it cools down(about 5 mins or so). I have replaced the ignition moduel, pickup coil, I have checked the vapor release valve, plugs, plug wires, maf and have set the timing. So could heat soaking be the problem, I didn't think it was the problem because it has stock manifolds. Or could it be the VATS key system? Please help!!!
Old Mar 5, 2009 | 07:17 PM
Ls2 GTO's Avatar
Car: 92 purple haze z03 z28
Engine: Lb9
Transmission: 5 speed
Re: Heat Soaking? VATS?
Is it turning over or is it like the starter not engaging. My 89 5.7 gta had a proble, that I thought was the vats but once I replaced the starter it corrected the problem. I had an issue with the car turning over 4 or 5 times to start but it turned out to be a dirty clogged fuel filter.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
