OIL COOLER???
Old Mar 6, 2009 | 12:58 AM
Dany89's Avatar
OIL COOLER???
When i bought my GTA in the trunk i found an Oil cooler i belive it's for the tranny oil but im not sure, Does any one know where it goes on the car??? it llooks like a little radiator. Does it affect my car if is not installed??? and if i does need to be installed back where does it go???
Old Mar 6, 2009 | 04:14 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: OIL COOLER???
These cars didn't come with tranny coolers. However you can use it for that purpose if you'd like. Route the lines however you feel looks best and mount the cooler in front of the radiator.
I installed a tranny cooler on mine. I removed the tranny lines from the radiator, changed the bend a bit, bought some new line and bent that, and routed the lines around the radiator to the front where I mounted the cooler. My trans doesn't get above 160 while driving anymore.
Old Mar 9, 2009 | 04:17 PM
Dany89's Avatar
Re: OIL COOLER???
Nice! where did you buy the lines???
Old Mar 10, 2009 | 04:25 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: OIL COOLER???
NAPA. Only needed about 12 inches of line, a couple of fittings, and a 3 way distribution block.
I'm using the radiator as a pre-cooler and then the aftermarket cooler after that to cool down the fluid a bit more.
My temperature sender is located in the return line to the trans.
Old Mar 10, 2009 | 07:21 AM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Re: OIL COOLER???
Why wouldn't you put the temp sensor on the line coming from the trans? Putting it on the return line gives you the temp after it's been cooled off. That doesn't tell you a whole lot about how hot the trans actually is because you have little way of measuring the heat output of the radiators.
Old Mar 10, 2009 | 03:09 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: OIL COOLER???
Is there a "too cold" for a trans? Or is getting it as cold as you can the best?
Old Mar 10, 2009 | 04:59 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: OIL COOLER???
There is a too cold but i'm not sure what that number is.
I want to know what temp my trans is using. That's the temp of the fluid the trans is using. More important than knowing what's leaving the trans.
You could run a dual temp setup if you want to see how well the cooler(s) cools.
Do some searches on this site and you'll find more in-depth info on why the return side is a more useful location.
Old Mar 11, 2009 | 08:00 AM
safemode's Avatar
Car: camaro rs
Re: OIL COOLER???
The following thread has a good explanation of different places to mount the sensor to get different data about the trans.
https://www.thirdgen.org/forums/tech...-m-hi-tek.html
Basically, temp wise, you want the coolant to be around 180-210. The trans should be in that range as well. Colder than that isn't good. The stuff is designed for the temp range and performs the best within it.
Old Mar 12, 2009 | 12:24 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: OIL COOLER???
There's a thread on here somewhere that includes a table of expected tranny life vs. fluid temp.
Old Mar 12, 2009 | 12:36 PM
Stephen's Avatar
Car: 87 GTA
Re: OIL COOLER???
Originally Posted by Viprklr
There isI want to know what temp my trans is using. That's the temp of the fluid the trans is using. More important than knowing what's leaving the trans
I would know know how hot the fluid AFTER the tranny uses, not what it starts with.
For all you know, the tranny could be cooking the fluid to 260 & running dual coolers, like you are, are what is needed to keep it low enough, to start out with.
tyeo098
Nov 30, 2015 06:27 PM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
