Ignition Lock Cylinder...
Old Mar 10, 2009 | 12:48 PM
gangsta_money23's Avatar
Car: 1982 Camaro Z-28
Transmission: manual
I posted this in the wrong place yesterday so Im deleting that one and now its here.
Ok problem is my ignition lock cylinder decided to lock up, the key wont turn it anymore and I cant get the car started or more importantly I cant get the key to the 'acc' position to remove the whole lock cylinder so i can replace it. I've asked a few places all ready and i've been told you yank it out with a slide hammer and a screw in attachment and it should pull it right out, i've also been told to drill the cylinder and once I'm deep enough it'll let me turn the cylinder to do it that way. I'd much prefer to yank it with the slide hammer but never used one on an ignition lock. Anyone have any experience doing this? any pprecautions i should take into considerations? Thanks alot
Old Mar 10, 2009 | 02:43 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: Ignition Lock Cylinder...
I have the same problem going on, except someone did me a favor years ago
by trying to steal the car, and cracking the column. I can't turn my key more
than a quarter turn, So I have to pull/push the aluminum inside lever inside
the column back with a screwdriver to start and stop the car.
and! I cannot even remove my key, it is a permanent resident!
Im sure it cant be too difficult, it's been on my "to do" list for months!
Old Mar 10, 2009 | 03:39 PM
I'll let ya know how easy it goes for me later on today after I pull it. At least you got left with a way to still start the car, are you able to move the steering wheel or does that stay locked?
Old Mar 11, 2009 | 08:59 AM
bigtom68's Avatar
Car: 88 iroc-z
Engine: 5.7 tpi
i just replaced my lock cylinder. napa has the chrome ones for like 20 bucks. you have to take the steering wheel off and there is a tool that napa sells to push down on the steering lock plate. then you remove the screws for the turn signal switch. once you do that pull out a little plastic piece next to a brown torx screw. take the screw out and the cylinder should slide out. i didnt need it in acc or on just off and i did it in maybe 15 minutes
Old Mar 11, 2009 | 06:38 PM
TPI's Avatar
Nah, I got lucky and I can move and drive the car.. but I have
to be super paranoid about leaving it unattended, because it is just
asking to be stolen!
Luckily.. she is a garage baby!
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Racerx974
Sep 19, 2015 10:16 AM
Denricci22
Sep 18, 2015 09:02 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Jlanz55
Sep 6, 2015 02:35 PM
