LG4 Power!
Old Mar 14, 2009 | 04:00 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
LG4 Power!
Here's an angle to consider if you're torn between modifying your 305 or going with the crowd and ditching it in favor of a 350:
https://www.thirdgen.org/forums/orga...ml#post4079915
Old Mar 14, 2009 | 06:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Nitrous is $3.50 a pound last I checked. If you don't have a bottle heater, you'll get 4 - 6 passes out of a fill, depending upon how big a shot you're spraying.
Low non-recurring cost, high recurring cost.
Old Mar 15, 2009 | 11:52 AM
86LG4Bird's Avatar
Re: LG4 Power!
75 shot.
~800 psi yesterday (no heater).
N2O flow of .06 lb/sec x 14 sec/run = .84 lbs/run.
With the 15 lb bottle, that's an easy 12 runs.
For a car that will make 30 passes a year at most, this is by far the most economical way to let her get her kicks.
Obviously if you want the power for the street, this is not the way. I was just amazed at dropping almost 2 seconds from the car's best NA time.
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
ambainb
Aug 29, 2015 12:43 AM
sailtexas186548
Aug 24, 2015 10:11 PM
