blown up plastic thing!
Old Mar 15, 2009 | 05:45 PM
blindslide's Avatar
Car: 1984 camaro z28
Engine: LG4
Axle/Gears: stock
so i started my car today, and i heard the best sounding exhaust leak of my life! i loveit. low grumble... but anyway...
there are two lines coming off each header that run to this plastic piece on the engine on the passenger side, the plastic piece is part of a unit that bolts on top of the engine near the front.
what is it?
im gonna plug the line from the exhaust manifolds later so it doesn't hurt anything.
by the way,
its a 1984 camaro w/ 305 (LG4 engine). it's also a cali car (smog parts on everything.....)...
all help is much appreciated.
Old Mar 15, 2009 | 05:48 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: blown up plastic thing!
sounds like part of the A.I.R. system. Emissions controls.
Old Mar 15, 2009 | 05:55 PM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
which part?!
i can post pics in a little bit if anyone wants to see,
the guys at my kragen don't even know what it is.
Old Mar 15, 2009 | 06:10 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Pics would help.
Old Mar 15, 2009 | 06:33 PM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
chilton came in handy for once!
it is the Air Management valve?
doesn't give me too much of a description....
does this affec engine timing, or performance?
is it neccessary to have?
(of course it will be for smog, but for now do i need it? )
and as for replacing it, could i get one from a junkyard?
i also need the lines that run to the header....
it tore everything apart when it blew up.
Old Mar 15, 2009 | 06:45 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
you should be able to get all the parts used, and it does not hurt performance or mileage. I'd recommend you leave it on all year round, not just at inspection. I heard that in cali the cops can pull you over, and make you pop your hood, and if it looks wrong, they can impound your car until you prove it's all legal as they saw it. If not, they can crush it. If that's true, don't risk it.
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Mar 18, 2019 08:29 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Bob88GTA
Aug 18, 2015 03:31 PM
