Valve covers
Old Mar 16, 2009 | 07:40 PM
TRstallion's Avatar
Car: 1990 Camaro RS V8
Engine: 305 TBI
Transmission: automatic 4-speed
Valve covers
Ok i have a 1990 RS V8 camaro. I was working on it and had to replace a valve cover gasket. My dad and I decided that we'd put new covers completely along with new gaskets on both sides. We got the passanger side in yesterday. Today I got the driver side valve cover off. Now I cant get the new valve cover and gasket on. Theres fuel lines and computors and exhaust piping in the way. I tried to remove the exhaust piping but i cant get to 2 out of the 4 bolts holding it in. What should I do?
Old Mar 16, 2009 | 08:42 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Re: Valve covers
It will just take some elbow grease. Set the gasket in the groove on your valve cover, maybe put a little rtv on it to help it stay on the cover, and get it down on there. those lines should have a little play in them. If you got it out it will go back on!
Old Mar 16, 2009 | 09:30 PM
TRstallion's Avatar
Engine: 305 TBI
Re: Valve covers
yea they do but the only thing is the alternator is in the way of the lines and my uncle says i should just remove the alternator and the use that open area to move the fuel lines out of the way
Old Mar 16, 2009 | 09:56 PM
BCdawg57's Avatar
Re: Valve covers
Well, then there you go!
Old Mar 16, 2009 | 09:59 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: Valve covers
you will have to go that route. had to do the same when i ran new fuel lines to my TB. gives you alot of room to work with.
Old Mar 17, 2009 | 09:34 AM
TRstallion's Avatar
Engine: 305 TBI
Re: Valve covers
Yeah I was gunna do it yesterday but of course homework interferes with all the fun. Luckily I've got a couple days to work with it.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
