Engine bay cleaning.
Old Mar 17, 2009 | 08:33 AM
paradigmqc's Avatar
I just want to know what do you remove when you clean the engine bay... I know that a lot of wire are not necessary with a Carbed engine..
Let me know if you want please
Old Mar 17, 2009 | 10:15 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
You don’t have to remove anything.
Just cover the throttle opening, and don’t spray anything into the alternator.
Run the motor after cleaning to evaporate any water that might be puddling.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Mar 17, 2009 | 12:12 PM
joshwilson3's Avatar
Re: Engine bay cleaning.
What are some good degreasers that won't damage anything or stain any aluminum? Something that will get rid of all the road grim on the shocks, calipers,and front of the engine.
Old Mar 17, 2009 | 12:27 PM
NINÅ's Avatar
Transmission: 765R4
CLEAN MACHINE
I have used GUNK brand degreaser.
It will remove some types of engine paint so you might want to test an inconspicuous surface first.
Never noticed a problem with aluminum.
Make sure you cover your fenders with waterproof drop cloths.
Happy Racing!
Old Mar 17, 2009 | 12:28 PM
paradigmqc's Avatar
But I meaned... there is a lot of wire that are not required. I wanna make a clean engine bay not just clean the grease lol :P
Old Mar 17, 2009 | 05:11 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Depends what you mean by "required..." a lot of those are necessary for various components to function properly (gauges, sensors), wiring that would be safe to remove depends on what modifications you've made (ie, replacing CC-carb or A/C delete). I'd recommend not touching anything unless you've got wires with one end going to nowhere, unused connectors and the like... then it would be safe to remove those (although not necessarily a good idea)
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
