junk yard time?
Old Mar 17, 2009 | 11:14 AM
CHAMARO's Avatar
Car: 92 Camaro Z28
Engine: 383
Axle/Gears: 9"
junk yard time?
2 questions
1 - i have a power pulldown hatch. i want to swap to manual non power latch. is that possible? junk yard model will bolt on? will i need to change lock cylinders or just swap them?
2 - i am fabricating an aluminum sheetmetal center console and i threw away my oem console(doh!) can someone tell me what the width measurement of the console is?
Old Mar 17, 2009 | 12:45 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: junk yard time?
My easiest solution was to remove the trim panel hiding the latch assembly, cut the wires, andthen drill a couple of holes through the whole pull down assembly. A couple of 1/4" screws, and reinstall the trim. This worked as I hoped for 2 more years without issue. Sounds ghetto, but didn't show at all.
Old Mar 17, 2009 | 11:16 PM
CHAMARO's Avatar
Car: 92 Camaro Z28
Engine: 383
Axle/Gears: 9"
Re: junk yard time?
i may end up doing that or welding it, it isnt broken but i want to lighten up the car and i dont need a motor back there but if i have to change keys and cylinders then i will remove the motor and rig up the latch with bolts or welds. i know people have swapped them to manual latch but not sure about key and cylinder?
Old Mar 17, 2009 | 11:52 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: junk yard time?
I'm not sure about the lock cylinder either. Seems to me the pull down has a cap that snaps onto the lock with the cable in it and the non has a rod off the back of the cylinder. The cyl may interchange if you get the rod. The problem I do see is the bracket the latch is bolted to. The pull down bracket isn't the same as a non pull down and it's welded into the rear body panel.
TheJoeY88
Dec 31, 2016 07:30 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
bbernardo94
Aug 19, 2015 05:25 AM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
