Wipers wont move!!!!
Old Mar 18, 2009 | 06:23 AM
Gary Berg's Avatar
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
ok im at school right now so this is gonna be short. i woke up this morning and go to turn my wiper blades and they dont move tried like 454957462378 times and they wouldnt budge. Please help!
Thanks, Gary
Old Mar 18, 2009 | 07:22 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Wipers wont move!!!!
Did you check the fuse?
Old Mar 18, 2009 | 03:19 PM
Gary Berg's Avatar
Axle/Gears: Posi.
no i didnt but i will
Old Mar 19, 2009 | 08:17 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
I recently lost my wipers too... fuse is 25A under the dash... toasted... hope yours drew too much current from trying to scrap frost off the glass... unlike mine... my motor is TOAST... lol burnt up and then blew the fuse... good luck
Old Mar 20, 2009 | 02:39 AM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
If changing the fuse doesnt do the trick... or only does the trick for about 3 cycles, you need to look for a short. Look for exposed wires, if your lucky, this is the problem. If not, you're probably going to have to get something like the motor, or the switch in the steering column replaced.
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
gord327
Oct 3, 2015 01:25 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Hal87
Sep 26, 2015 09:26 PM
