1983 Firebird fuel mix
Old Mar 18, 2009 | 12:21 PM
leejo2005's Avatar
Car: 1983 Firebird S/E
Axle/Gears: 9 Bolt Posi+Disk 3.70
I recently got myself a 1983 Firebird S/E with the 305 4bbl V8. The car is running extremely rich and my mileage is suffering from it. I've been getting the code 44 from the computer and the check engine light comes on if I let the rpms stay low for long enough when the engine is hot. I've tried putting in a new o2 sensor and changing vacuum lines and checking for leaks and I can find no solution. I was hoping somebody might be able to prod me down the right path so I can get this fixed.
Nearly forgot to mention. The previous owner has recently had the carburator professionally rebuilt. It's the computer controller Q-jet.
Old Mar 18, 2009 | 01:41 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: 1983 Firebird fuel mix
https://www.thirdgen.org/service-eng...ht-error-codes
Code 44 = Oxygen Sensor Lean
Code 45 = Oxygen Sensor Rich
Check codes again. Sounds like you just got mixed up.
Old Mar 18, 2009 | 02:20 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
no, the 44 would be right. The computer thinks the engine is running too lean, so it commands more fuel, then the engine runs rich. Start by replacing the sensor.
Old Mar 18, 2009 | 02:22 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
And I mean the first new sensor might be bad. rare, but possible. If that doesn't fix it, then I'd wonder about the carb. I once had one of those getting 8 mpg.
Old Mar 18, 2009 | 02:46 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Okay, thanks, understand now.
Old Mar 18, 2009 | 03:03 PM
leejo2005's Avatar
Yeah, the computer thinks it's lean and compensates by pouring gas down the hole. It smells like I'm driving a shell station around.
I'm going to poke around some more tonight because I really think it's a vacuum leak somewhere but I can't find it. Luckily for us cars made back then used vacuum for just about everything.
Glowsock
Jul 24, 2025 03:15 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
justin57
Aug 20, 2015 07:05 PM
MENINBLK
Aug 5, 2015 11:58 PM
