305 Heads
Old Mar 19, 2009 | 02:55 PM
blindslide's Avatar
Car: 1984 camaro z28
Engine: LG4
Axle/Gears: stock
305 Heads
My dad has a set of heads off a 83 camaro, that were shaved to 52cc, w/ aftermarket springs, lighter valves, roller rockers, and a bead blast inside the cylinder(he said it smoothes out the inside?).
anyway, he used these heads on his circle track car that had a 4 bolt main 5.7 in it, and he got like somewhere into the 11:1 compression. i was wondering if i were to install these heads (which are still in fairly good condition, only used 2 races before his new heads came in the mail) if they would see good use on the LG4?
the heads would be matched to a 650cfm holley, and airgap intake, but i still have the stock exhaust.
Old Mar 19, 2009 | 04:43 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 Heads
should give you around 9.2:1 compression, depending on your piston-to-head clearance.
Old Mar 19, 2009 | 05:41 PM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
Re: 305 Heads
I'll be using stock internals for the LG4 with the new heads and intake. what kind of hp should i expect after installation?
Old Mar 19, 2009 | 07:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
About 155.
The heads will be fine to use (did they get bigger valves as well?), but don't expect much without doing other things, especially exhaust. And air cleaner (I imagine you won't be using a stock air cleaner on a Holley), and cam.
Exhaust (headers, 3" all the way back) with stock heads would give a better power gain than those heads with stock exhaust.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
