Where does cat air tube bolt to?
Old Mar 19, 2009 | 04:35 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Where does the air tube from the cat bolt to? Does it bolt to the rear of the pass head or to the last manifold bolt/stud or???
Old Mar 19, 2009 | 05:00 PM
50bmgshooter's Avatar
Re: Where does cat air tube bolt to?
if you mean the tube mount then on my 91 it was on the back of the passenger side head
Old Mar 19, 2009 | 08:04 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
The back of the passenger head. It's like that on all the cars with that tube.
Old Mar 19, 2009 | 08:11 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
Ditto. Pass side head, outer-side (nearest the climate box) The check valve that is on the pipe should sit just atop the valve cover.
Old Mar 19, 2009 | 10:15 PM
89RsPower!'s Avatar
thanks for the replies, I figured it was one or the other but it's been so long I couldn't remember..
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
drathaar907
Aug 6, 2015 04:20 PM
