Car never seems to start right
Old Mar 19, 2009 | 05:30 PM
venom204's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Ive got a 91 camaro that when i go to start it sometimes it will start right up sometimes i turn the key and it takes 5 sec, maybe 10secs, just depends and i have no idea why. Sometimes it wont even start i need to turn the key off and try it again and then it usually works. When running the alt shows about 13-14 on the gauge or so when running, When i shut it off and then turn the key on it shows it alot lower like 8 or 9. If i start the car and shut it off a few times it will act like the battery is going dead, maybe it is. The battery terminals are clean and i just don't know where to go from here. I put all the info i know in here hopefully someone has an idea. Its got a 305 in it.
Old Mar 19, 2009 | 06:24 PM
bubbasexy's Avatar
Re: Car never seems to start right
check your connection it sound like one of your ends is corroded or not tighten down all the way
Old Mar 19, 2009 | 08:03 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Also check the connections at the starter. Might be a loose solenoid on the starter. Had this happen to me on an S-10.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
