Adjusting hydr roller lifters
Old Mar 22, 2009 | 06:49 AM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Hi!
I just got these lifters http://www.lmperformance.com/6304/43.html.
The difference are that the spring in the lifter are so soft that when you adjust the roller arms the spring in the lifter just compress so you dont now how much you should adjust the nut on the roller lifter.
Someone have a clue how to do it?
Old Mar 22, 2009 | 10:34 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Adjusting hydr roller lifters
If you run the engine for a minute or so, they should firm up with oil. To get to that point you could just eye it by adjusting rockers until the plunger in the lifter is still contacting the retainer pin of the lifter.
It sounds like you may not have soaked the lifters in warm oil over night before the install. That usually makes them firm enough for a good initial adjustment.
Only ajust a lifter that is on the base-circle of the camshaft at the time.
Once it's done don't go back and adjust it again because the lifter plunger has collapsed some due to lack of oil pressure.
88SS6SPEED
Nov 11, 2015 07:05 AM
codeysabatini
Nov 10, 2015 04:07 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
RyanJB
Sep 14, 2015 03:39 PM
dimented24x7
Sep 6, 2015 03:51 PM
