Oil all around my oil filter.
Old Mar 23, 2009 | 08:29 PM
mustangslayer86's Avatar
Car: '88 GTA / '93 Z28
Engine: L98(350) / LT1 (350)
Transmission: 700R4 / 4L60E
I'm sure the majority of people here change their own oil as well so as I was changing my oil today I realized the entire area around it is either very greasy or very oily. Its a black slimy substance when wiped on my hands. So I just wanted to see if anyone else has the same situation. It isn't much, but its enough for a thin layer. My brother thinks it may be leaking oil, but every time I've changed the oil it's been there and the amount doesn't appear to have changed. Every time I pull my car out I check for substances leaking (Of course, those of you who have been in the transmission threads know of my power steering fluid leak) and I've never seen oil on the ground. I always dab it and get the color and all its been recently is power steering fluid.
Thanks for putting up with me. Ever since I've bought this Camaro I realize how lucky I am to have it because my friend has a 2002 dodge stratus with so many more problems and I'm grateful how well these things run and the long lasting life. So thanks for taking the time to answer my questions and keep my Camaro on the road.
Old Mar 23, 2009 | 08:51 PM
R.O.B.'s Avatar
Re: Oil all around my oil filter.
Yes, something is leaking in order to leave that film everywhere. Most likly, it was your power steering fluid (I say this because you said you had a leak here) getting splattered all over the place while you were driving.
Old Mar 23, 2009 | 09:23 PM
Good call! I'll let you know if your right wednesday when I take it to the shop. That give me a little more peace of mind. :P
EDIT: It is on the bottom of my engine block. So it may not be power steering fluid.
Last edited by mustangslayer86; Mar 23, 2009 at 09:52 PM. Reason: Additional Details.
Old Mar 23, 2009 | 10:45 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
how tight and what type is your oil filter? It its not tight enough it can leak...it happened to me once with a Fram or Purolator, can't remember...
jrdturbo
Mar 31, 2016 02:58 PM
bigjay89gta
Oct 15, 2015 08:04 AM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
