a big F. up on my part..
Old Mar 22, 2009 | 09:24 PM
got-stylez's Avatar
Car: 1988 trans am GTA
Engine: 5.7
Transmission: stock
Axle/Gears: stock
okay so.. my car was over heating.i bought a new thermostat for it... i startd to take it off.. i got 1 bolt loose.. then the other bolt..broke off in the intake!!! ok so me and my dad started to drill it out... we got thru it.. went to try to get it out with a easy out thing..its to get out broken bolts after u drill a hole thru.... anyway.. 1 turn of the "easy" out..and snap! it broke... damn piece of crap.. so we drilled it for nothing lol.......... started over.. and i started to drill again ..i guess it slipped off the bold and went into the intake so now.. theres a bolt..well half a bolt..and a big ol hole right beside it! anyway to fix this without gettin a new intake? i plan on getting a new intake ddown the road but i have no money for 1 right now..
oh and yeah..i know i should have paid more attention..
Old Mar 22, 2009 | 09:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: a big F. up on my part..
I'd be looking for a new intake.
Old Mar 22, 2009 | 10:01 PM
got-stylez's Avatar
Engine: 5.7
Transmission: stock
Axle/Gears: stock
i actually need one.. the intak eon it now is the 1 without the 9th injecter... and i need the 9th injecter lol do u think ... like gasket sealer or some kind of something i could put there.. lol its not in the thermostate hole.. its on the threads where the bolt goes
Old Mar 22, 2009 | 11:40 PM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Did you try welding a hunk of bar to the bolt to use as leverage? Or is the bolt now too drilled out to weld onto? If you dont have a welder For... well... about the cost of a new intake you could buy a wire feed welder from Lowes or somewhere. They're real easy to use. And you could fill in that hole, too, if I'm understanding what the problem is.
Anyway, that's how I'd do it.
Make sure to use lots of WD40.
Old Mar 22, 2009 | 11:47 PM
got-stylez's Avatar
Engine: 5.7
Transmission: stock
Axle/Gears: stock
i dont have a welder.. but yeah i'd read a few other forums about bolts getting broke off and what they use... so far i'v read that welding another bold on it is the best option.. BUT if i egt some weld splatter anywhere else im kind of F'ed then.. or..so i'd read... i would heat it up.. but its right next to the fuel lines.... is that a good idea?? lol .. im pretty sure i spend probably $25 in drill bits... they all are junk! they either arnt sharp enough to cut it.. or i get a good cut going then bam! its broke.. i had it all the way thru then the damn easy out thing broke... i'd read plenty of forums that say that aint "easy" lol..... now that i know that.. i wont use em again
Old Mar 22, 2009 | 11:58 PM
Car: 1989 Camaro RS
Engine: 305 TBI
Yeah, you have to be careful of fuel and splatter, but the wire feeds wont splatter much if you're conservative about getting it on there, and if you have any kind of ceramic grinding wheel, (like a dremel or foredom, but you could hotwire an old fashioned two speed reversable) you can grind off any splatter. Because its an intake manifold, you dont have to worry about critical failure if it gets scratched a bit... all it does is direct air flow. Well- best of luck. I know what its like to be kinda stuck on a project because of a broken bolt or something.
Old Mar 23, 2009 | 12:03 AM
92RSStud's Avatar
Car: 1992 Rally Sport
Engine: 355CI
Axle/Gears: 10bolt stock gears
pictures would help, but from the sounds of it... no welder... so that options out... a chisle sometimes works.. but since you allready drilled it out... maybe not... drill it out... but that didn't work.. bud you better just park it till you can shell out $$$ for a new intake maybe go to a junk yard and get one for $20... and use that till you can get a performance intake...
Old Mar 23, 2009 | 12:09 AM
rojas1826's Avatar
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700r-4
Axle/Gears: 2.73 lsd
daaaam same thing happened to me! car started overheating i thought it would be a fun project to change the thermostat myself and then both of the bolts broke!!! and i tried using the drill kit for removing broken bolts and they just brake so easy i dont have a welder or experience welding so i saved up for almost a year now and just today i spent 900 bucks on a set of the vortec heads everyone is talking about and the edelbrock tpi intake for vortec heads now dont make fun that i spent so much i know there are other cheaper alternatives but i always wanted to beef up the 305 and any advice on cam selection for this setup would be great now that i have the motor apart
Old Mar 23, 2009 | 01:32 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I have a MIG welder and it has saved me so much money on broke bolts. Just weld on another bolt to the old one and with the heat it usually comes right out.
Old Mar 23, 2009 | 11:25 AM
got-stylez's Avatar
Engine: 5.7
Transmission: stock
Axle/Gears: stock
i'd get a pic..but my camara broke lol.... but another question i have.. is there a way i could seal the hole? after all its just into the treads where the bolt goes.. if i can get 3 sides o the bolt to have threads.. is that enough????????
Old Mar 23, 2009 | 12:05 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Old Mar 23, 2009 | 12:13 PM
chesterfield's Avatar
Car: Pontiac
I'd be done looking and have it replaced already.
Old Mar 23, 2009 | 03:49 PM
got-stylez's Avatar
Engine: 5.7
Transmission: stock
Axle/Gears: stock
kind of hard when i work construstion and im getting almost no money!
Old Mar 23, 2009 | 04:03 PM
naf's Avatar
naf
More reason to quit screwing around and wasting money on attempts at a half-arsed solution. I know it's tough, but check the JYs near you, craigs list and the for sale/wanted boards here.
Old Mar 23, 2009 | 04:29 PM
got-stylez's Avatar
Engine: 5.7
Transmission: stock
Axle/Gears: stock
the junk yards around here are stupid!!!!!!! 1 my buddys found a air filter and maybe about a 10" piece of rubber stuff that goes to the intake with it... the said $20 for it.. i was like wtf.... all that for a airfilter but yeahi found 1 for it... $50..but i aint gots no money.. so it'll have to wait
Old Mar 23, 2009 | 06:55 PM
92RSStud's Avatar
Engine: 355CI
Does this make any cents? to anyone?
You didn't want to pay $20.. cause you thought it was rediculous... but you wanna shell out $50????
Sounds like your terrible at bargaining.. your supposed to go lower not higher.
Old Mar 23, 2009 | 07:19 PM
got-stylez's Avatar
Engine: 5.7
Transmission: stock
Axle/Gears: stock
no they wanted $20 for a air filter that was used..... and im goign to pay 50 for the hole intake and everything...........
Old Mar 23, 2009 | 07:46 PM
92RSStud's Avatar
Engine: 355CI
thats better... now i understand.. Why $20 for an air filter... that is rediculous... i paid.. $6 bucks for mine brand new... and $150 for a k&n that was the filter, the bottom peice.. and a filtered.. top peice.
Old Mar 23, 2009 | 08:17 PM
got-stylez's Avatar
Engine: 5.7
Transmission: stock
Axle/Gears: stock
i'd like them to answer that too lol....... they are very high...
Old Mar 23, 2009 | 08:18 PM
got-stylez's Avatar
Engine: 5.7
Transmission: stock
Axle/Gears: stock
oh and... i got the bolt out..and the "easy" out im going to use some JB weld on the hole.. and try to do it this way.. hopefully it will work.
Old Mar 23, 2009 | 10:38 PM
Car: 1989 Camaro RS
Engine: 305 TBI
Congrats on getting the bolt out.
JB weld is like a high grade rubber cement. The website says it can take 500oF and will fail in 10 min at 600oF. I'd say try and get it replaced ASAP, but the JB should hold.
Old Mar 23, 2009 | 10:48 PM
got-stylez's Avatar
Engine: 5.7
Transmission: stock
Axle/Gears: stock
i hope it does til i get a new intake!!!! it should though.. its not going have have any pressure on it besides me tighting it down.
TPI TERR
Dec 6, 2006 10:29 PM
anubiscougar
Jan 5, 2004 10:45 AM
Makaveli
Jul 24, 2002 02:53 PM
yOp 84 Recaro
May 8, 2002 08:51 AM
