ok.. nub here.. which is better.
Old Jan 3, 2004 | 11:40 PM
anubiscougar's Avatar
Ok... i know lower compression is better for blown or turbo engine.. so... is higher better for non blown/turbo.. what about NOS... higher as well? i think so.. but please correct me if i'm wrong..
now.. here's the real thing... ok, looking at this site.. reading these specs..
HYPEREUTECTIC FLAT-TOP PISTONS: 58cc=12.6-1, 64cc= 11.7-1, 72cc= 10.8-1, 76cc= 10.3-1
ok.. now.. they ran the 72cc=10.8-1 compression. what's the CC part.. the size of the piston head? or.. how big/tall it is? or.. what..
Also.. does that cubic cenitimeters make much of a diff there? like.. which would you get more power from, on a non blown/turbo/nitrous car.. the 12.6-1 w/ the 58cc, or the 10.3-1, 76cc? what really is the difference in other words... do these #'s have to match up w/ the heads.. i was told they do... what about w/ the cam, no.. correct?
thanks. :-)
Old Jan 4, 2004 | 07:51 AM
ede's Avatar
ede
yes, basically higher is better for NA and lower for power adders. the cc is the volumn of the chamber in the head. as for what makes the most power you need to look at the entire combination and not just the compression ratio.
Old Jan 4, 2004 | 10:56 AM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
I'd get a book and start reading up on engines. The higher the compression the more power potential. But if you make too much compression on a N/A engine, you'll have to start running race fuel just to get combustion right. I am almost sure you can run more compression with aluminum heads over cast irons (help me out guys if I'm wrong) but that's just what I have read.
Old Jan 4, 2004 | 07:04 PM
that's what i thought.
so.... about what compression would you have to start running race fuel? which... would suck, rofl. you can run 12-1 compression on top notch octane can't you?
Old Jan 5, 2004 | 12:58 AM
zerotosixtyV8's Avatar
Car: Camaro
your timing is also critical as well as the the material your heads are made of, an cooling system. Also higher compression is fine with nitrous, but not with forced induction. 12:1 CAN be run on the highest rating pump gas with base timing at 0 degrees and very little advance throughout the powerband and aluminum heads but you are playing with fire. everything has to be dead on otherwise you've just toasted your motor unless you know where you can get leaded gas lol. I'd say 11.5:1 with aluminum heads and 11:1 with iron heads is the most you'd want to run if you are going to rely on pump gas.
Old Jan 5, 2004 | 09:20 AM
why higher compression with aluminum? aren't aluminum less durable?
Old Jan 5, 2004 | 10:05 AM
ede's Avatar
ede
heat disapation is better with alumnum than iron
Old Jan 5, 2004 | 10:45 AM
Guest
Guest
Posts: n/a
The cam profile has alot more effect on what compression you can run than anything else.
gta892000
Aug 11, 2019 11:16 AM
Grant2k
Apr 4, 2016 08:21 AM
gta892000
Sep 16, 2015 12:37 AM
Thornburg
Sep 1, 2015 03:39 AM
italiano67
Aug 31, 2015 06:04 PM
