Noticed an oil-cooler, is this standard?
So, I was changing the oil this weekend, and noticed a coolant hose running into the oil-filter flange. I could kick whoever installed the Oil Filter, in the *****......I literally broke a filter removal wrench trying to get it off. Ended up having to punch a screwdriver through the filter, and use my body weight, pushing on the screwdriver with my foot an entire rotation and a half before I could twist it with my hand. Anways......I assume it's an oil-cooler, did these come standard in the GTA?
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Noticed an oil-cooler, is this standard?
Yeah, it most likely is....my camaro came with a engine oil cooler....even a power steering cooler....but yeah some came with those...some didn't.
or from someone not changing the filter with their oil
have seen this happen before more than once
but usually like you said its from some one way over tightening the filter
UltRoadWarrior9
Sep 2, 2015 08:24 PM
