Can I put a new crank in a motor instead of machining the old one?
Old Mar 27, 2009 | 01:04 AM
PPM's Avatar
PPM
Car: 1991 Chevrolet Camaro Z28
Transmission: Tremac T-56 6 Speed
Axle/Gears: 10 Bolt 3.73 POSI
The #5 Rod bearing siezed and spun the crank. Is it possible to put in a brand new crank instead of welding and polishing the new ones?
Old Mar 27, 2009 | 01:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can I put a new crank in a motor instead of machining the old one?
Of course.
Old Mar 27, 2009 | 07:49 AM
rippin ron's Avatar
Car: 91 Camaro RS
Axle/Gears: 4.10
Keep in mind a new crank will need to be measured and likely machined to work. There is no such thing as an out of the box part.
Old Mar 27, 2009 | 12:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I imagine you will need a new rod, or machining the existing rod as well. If you get a new rod you'll want it balanced.
At the very least you'll want to mic everything, and or plastigauge it.
Personally i'd just machine the crank and get undersize bearings. That avoids needing it re-balanced.
italiano67
Dec 11, 2016 09:21 AM
gta90
Sep 15, 2015 04:00 PM
TheExaminer
Aug 26, 2015 04:59 PM
slade5612
Aug 11, 2015 07:19 PM
