help- do I need those metal insert on intake gasket
Old Mar 28, 2009 | 02:11 PM
kymission's Avatar
ok,
I just pulled the heads and had them redone, when putting things back together, (305 tbi stock motor by the way) I delivered the heads to the machine shop so I didn't clean the gaskets off. As a result I didn't know if I had the inserts or where they went so I didn't use them. After putting everything back together I see a used insert below the car. So I know they were there, but I didn't use them. Do I need them? what did they block off. I sure hope I don't have to tear the motor down again to put them in. Any ideas would help. thanks
Old Mar 28, 2009 | 02:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: help- do I need those metal insert on intake gasket
The inserts limit of block off exhaust gasses from passing through the manifold to help warm the carb up when it's cold.
If your manifold doesn't have a crossover you don't need them.
If you need them, one side is usually blocked off and the other side is a restriction.
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Wife'sCar
Aug 22, 2015 01:46 PM
89mulletbird
Aug 12, 2015 07:08 PM
