Changing spark plugs / thinking about suicide
Old Mar 28, 2009 | 02:32 PM
Kolby's Avatar
Car: 1988 Trans Am GTA
Engine: 350 5.7
How do you change the last two on the passanger side? I have an 88 GTA w/ a 350. Ive never seen spark plugs that were so hard to get to.
Old Mar 28, 2009 | 02:40 PM
50bmgshooter's Avatar
Re: Changing spark plugs / thinking about suicide
go from under the car
plug socket and a wrench
thats how i did mine
Old Mar 28, 2009 | 03:19 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Be safe though. Use jackstands on a hard surface.
Old Mar 28, 2009 | 05:42 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Get a set of headers and it will not be as hard.
Old Mar 28, 2009 | 05:57 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I did mine from above, with a ratchet and a spark plug socket, and that was while I still had the stock manifolds and A/C.
Old Mar 28, 2009 | 06:15 PM
chaoz28's Avatar
Car: 87 formula/69 beetle
Engine: 355/2.1
Transmission: T.C.I streetfighter th350/5 speed
Axle/Gears: 3.73 lsd/
mac sells a nice spark plug puller 3/8 drive with 4 joints its around 40 bucks and ive never found a plug i cant get out.. even on flat 4 engines.. but you shouldnt even need this to get yours out. remember you can always go in and break it with a 5/8 stubby wrench..
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Jan 29, 2017 07:00 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
