Air Conditioning
Old Mar 29, 2009 | 01:25 PM
87TPI305's Avatar
Air Conditioning
Just got another 1984 Camaro sport coupe. I want the air conditioning out of it cause i dont use it at all. How can i take it out perfectly without any problems? If you can help me send me a message or reply to this thank you.
Old Mar 29, 2009 | 02:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Drain the radiator and remove it. Pull the top section off the AC/heater box, disconnecting wiring as you go. Unbolt the AC compressor. With someone helping, pull the evaporator and condensor, compressor, hoses, et al, out as one unit. Remove the lower half of the AC/heater box (screws are inside the passenger compartment). Remove the AC ducting inside the car and the AC/heater control with vacuum lines & cables. Find the heater-delete box, fan, heater control, etc., install them.
Old Apr 11, 2009 | 06:02 AM
vortek's Avatar
Car: '89 RS
Engine: 350 Vortec
Transmission: TCI 700R4
Axle/Gears: 3:73 Eaton
Re: Air Conditioning
....is there that much of a difference between the AC/Non AC duct work?
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
jackhammer
Aug 15, 2015 10:04 PM
