What is this part?
Old Mar 29, 2009 | 02:22 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
What is this part?
What is the part under the Throttle body called ? The one that the sensor is plugged into. Also where can I buy one of these parts?
Old Mar 29, 2009 | 03:10 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: What is this part?
IAC-Intake air control valve.
Old Mar 29, 2009 | 04:56 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
im looking for the IAC plate/valve body? i dont know what its called? the part that the IAC screws into.
Old Mar 30, 2009 | 08:06 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
There are two sections to that piece one side is for the IAC (intake vacuum) and the other side is a heater for the TB. Coolant passes through the connections and heats the TB in cold weather. A lot of warmer climate people bypass the coolant, to lower temps.
If you need a replacement go back the the manufacturer of the TB for the piece, after market. Or just look for an OEM TB at a junk yard, Auction, or parts swap meet.
Why do you need one and what kind/brand is it?
Old Mar 30, 2009 | 10:20 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
tpi parts on ebay sells them
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
